Hi all I am going to try to get back at my truck again. I left off with it starting with a gallon of Diesel just below the new electric lift pump but not when I use the fuel from the tank. The fuel pump seems to be pulling air and fuel from the tank. Is there seals at the tank transfer valve? I have checked the pick up in the front tank and all is good and in operating correctly.. What else is there to look at from the tank forward?? Also if you all recall when I did get her running when it shut down the fan came off and punched a hole in the radiator so getting that fixed this week so I can get this out of my garage.. She will be up for sale once it is running and drivable..
Thanks
Chris
Thanks
Chris
