Axle tag
Kdo58
Puyallup washington
Can someone give me some info on this tag for a 1987 f350
Sergey
Washington
Black dawg
sw mt
Thank you ! Very useful resource. I was able to identify my truck rear diff from its tag. Less luck for the front diff though, tag rusted beyond clear reading. Is there similar resource for older front diff tag info ?
What are you trying to find out?
Rear is 3l55 ......3.55 limited slip,
Front shows 3.54 no limited slip
Sergey
Washington
exactly that - I put last time (long time ago, > 10 years) ordinary gear oil into rear and front differentials. Now your information suggests that it was not quite right, do I need to put special gear oil for limited slip differential in rear
u2slow
bilge rat
Coastal BC
I use regular oil with the trac-lok (LSD).
Reason being they are already broken-in, (or who-knows how worn out) and I want the thing to grip all it can. So far no problems in 20 years with several different trucks.
