Silver Burner
Burnin' Oil&Rubber
So as it turns out, I discovered today that my Sterling rear axle is actually a 3.55 ratio and NOT the 4.10 that I thought it was! Since I'll be doing my 4X4 swap and my parts truck has 3.55 axles, I thought I was going to have to either swap rear gears or rear axles, but now I just have to put in the D50 w/ 3.54's in the front!
This all started when I was working on my truck and got under there and saw a "55" on the axle tag followed by the 10 25 and I went Holy Sheet. So I got online and plugged in some rpm numbers with my tire size and sure enough, based on my speeds at certain RPM's, I really do have a 3.55 rear end! I always figured that 55mph doing 2000 RPM's meant I had to have 4.10's, but doing the calculator shows I'd only be doing about 46 or 47 at 2000 if I had 4.10's.
So I guess a hell yeah is in order. Less work for me!!
, and a c6 with 3.55s.
