Titojeep
I've only been using my aux fuel tank / truck box combo as manual tank recently since I haven't had a chance to tie it into the factory tank. I picked up an adapter at my local supplier, but found that my filler tube actually runs a little down hill before going up to the filler neck. Regardless, as I observe the filler neck, I realize that it's almost level with the bottom of my tank box in the bed. Is there another entry point on top of my factory tank that I could tie into? How have any of you tied in your aux tank box into the factory tank? To be honest, I run Wast hydraulic oil and generally keep my tank box full of oil and mix it into the factory tank at a certain ratio. I'd like to have the ability to let the oil flow into the factory tank at fill up's rather than drain into 5 gal jugs, and then poor into tank. Kinda sucks with this southern heat here lately.
