R.Shackleford
I've searched the forums and have not found a definite answer so hopefully someone knows.
How long do I have to extend the rear drive shaft for the auto to zf5 swap.
My truck is a 4 door and I am extending the part before the carrier bearing nearest the transfer case on recommendation even though I think it would be easier with the drive shaft nearest the rear differential instead.
I have searched and came up with anywhere between 3 and 7 inches.
I measured my parts and came up with the zf5 being 5 inches shorter than the auto trans. The shop wants an additional 1 inch to be added to the drive shaft for room for play. If anyone can confirm this
I got my parts off a regular cab so the front drive shaft will work, but the rear donor drive shaft is useless.
Any suggestions are greatly appreciated and thank you
