ATS Turbo Vent Hose
RLDSL
Diesel fuel abuser
Arkansas
That fit's an 088 system if you do their valve cover mod with the CDR bolted to the air box , I don't know if it will work if you have a factory turbo valve cover .
onebadiditurbo
Bokchito /Oklahoma/U.S.A.
Ive actually got an extra one layin around my shop when i had on 88 series on my 6.9l that thing is a b***h to get in. If someone needs it ill let this one go for $25 plus shipping just pm me. As far as location the end with the gromet looking end fits in the valve cover while the other goes into a diaphram looking bisquit mounted off the intake box , its just the crankcase vent basically and oil from blow by deteriorates the plaxtic these things are made from like crazy .
Fozz
Camarillo, CA
Yikes! $35?? I bought one directly from ATS a few years ago for like $12-15, and they threw in a couple of ATS can coozies and stickers too!
david85
Campbell River, B.C.
Yes, that is for 088 (and maybe 085).
If I had to do it all over again, I wouldn't even put the hose to the valve cover. Instead I would make up a part similar to the banks turbo kits and install a hose from the front timing cover to the CDR valve. My ATS vent hose cracked on my and I had to scramble to replace it with something. The folks at the parts store showed me to the wall in the back of the stock room and let me hunt and peck through there for something that would fit. Works well, but I am still getting minor oil weep from the connections. Not enough to really drip or consume oil, but enough to ruin the "new engine" feel:puke:
RLDSL
Diesel fuel abuser
Arkansas
On mine I actually have a turbo engine so it had the turbo valve cover already, but it has an 088 ATS turbo on the thing , so I just left the CDR in the valve cover and made a mount on the filter box out of an old CDR I cut up and found an S shaped heater hose to connect it up. Works great.
