Anyone Using a Vormax Heated Fuel Filter?
hheynow
the misanthrope
SF Bay Area
Yup, that's my vegoil filter. I have the Plant Drive WVO conversion kit. The Vormax a great item.
mankypro
Learning Slowly...
Boulder County, Colorado
How often are you replacing elements? Is there a filter element # from Racor or other vendors for this thing so I'm not paying the wvo folks a 5,000% markup?
hheynow
the misanthrope
SF Bay Area
That depends on how well I pre-filter my vegoil and that I get the water out prior to filling my tank. Wet oil will swell the filter element faster than sediment will fill it. So my longest was about just under 5K and the shortest was 2,800 (when I was a stupid newbie) :D . It uses the Racor R90T (10 micron). Cheapest price is $23.46 HERE. Certainly not an inexpensive filter. It also comes in 2 & 30 micron ratings but a 2 will clog up too fast (waste of money) and a 30 is designed as a pre-filter so I won't use either of them.
mankypro
Learning Slowly...
Hrm. Since I have an extensive shelf stock of stock fuel filters I bought for $4.50/pc maybe if I decide to do this I'd plumb it in after the stock filter, or just wait till I run out of stock filters (it'll be a while). Thanks for the info.
Seven4eight
