Anyone swap back to throttle cable?
Rdnck84_03
Kansas
The most common causes of water in the fuel are either contaminated fuel from wherever you got it, or not keeping the tanks full which allows condensation to form on the exposed areas inside the tank this time of year.
James
frankenwrench
overkill is under rated!
Weatherford tx
James
Lol. Then I definately got bad fuel somewhere. Them tanks last about 5 days tops before refill.
frankenwrench
Weatherford tx
OK, so ipr checks out. Hpop pressures seem really mint, IPC seems great, and throttle percentage vs voltage is good. Gave up with the tec and just drove it. Acting like nothing is wrong whatsoever. Now I hang my head in defeat. I just needed a dealership pedal, an ipr nut to stay tight, and new fuel filter and seperator. But even still, the truck runs amazingly and thus far hasn't given me any issues today after testing. Even went as far as loading up my trailer and put my other 4 door dually on it (93 7.3 idi) and started pulling it around. Left the house (Ft Worth TX area) and banged gears to Little Rock AK. She did fine. No cel, no defueling, no dead pedal, and no trying to die when mashing the clutch. Gonna camp out the rest of the day and head back tomorrow. Hopefully all goes well
frankenwrench
Weatherford tx
OK so if I done made it there and back with a decent load (guessing around 10k) and no issues still I believe the issue is resolved finally. Bit of a runaround and a pain, but still good! Thank you all for your ideas and suggestions. Truly appreciate it oil burners!
