anybody ever do fiberglass
RLDSL
Diesel fuel abuser
Arkansas
There is a company, I don't know who, but Doug Bensen would know, that referbishes the dash pads. Basically vacuum forms a new skin on them. If you could find out who that is, it may be possible to have a new skin formed over the whole dash including the mod, to give it a truely factory look.
That would look amazing!
I don't know. I just remember that Doug Bensen told me he had his redone, and was real happy with it. Maybe he posted the info? Try a search.
diesel4me2
Camping is more importanter!
northern illinois
i'll have to try that. on an aside, do i need to primer this or do anything to it prior to painting? these are after final sanding. it looks bad, but the blends are good, after painting i don't think it will be noticeable.
Cincinnati Guy
Cincinnati, Ohio
Yes you need to primer it. The filler may bleed through if you dont. Man I worked in the fiberglass industry a few years working with this stuff day in day out, I may have to try something like this since I got loads of fiberglass and gallons of resin.
diesel4me2
northern illinois
Are you planning to paint the whole dash?
If so Remember to clean everything real good. I would use a primer that works on plastic and fiberglass, which should be just about anything.
just the area, then blend with vinyl paint to the rest of the dash :dunno
diesel4me2
northern illinois
update
so i've finally got some more work done on this. man it's problematic the way life gets in the way of projects LOL. here it is in its first coat of primer. i sanded all the dash down, now i don't have any wrinkles on it :rotflmao. first coat of sandable primer. hows it look? i plan on trying to hide the "cracks" with more filler. they appeared after i used my air compressor to get rid of any dust prior to painting, they showed up after i started to paint and could see them
F350farmboy
The Hornet
N.E Ohio
Yeah...What he said:D
Fix those small cracks and blend it in a little better on the pass. side and that will look factory ;Sweet
flatlander
plays dirty when losing
ft. wayne IN
What's your address Chris? I want to make sure I get my dash to you soon so you can have it back before the rally.
