jonleroy2506
Hey all,
I have a 1990 7.3 that isn't charging well. I have to jump it every 2 or 3 days. I've been researching and working on it for hours, and don't seem to be getting anywhere. Electricity isn't my strong point for sure
The alternator is just over a year old. The batteries are brand new, and I just replaced 3 of the 4 battery terminals. The voltage regulator is also brand new.
I put new spade connectors on the 2 little wires that run to the alternator, it seems as thought there used to be a factory connector there, but that is long gone and the wires each have a female spade on them.
At idle, the batteries show about 12.7 volts, and the alternator shows about 12.8. I'm at a total loss for what to do next. Any ideas would help
The one thing I haven't checked yet, as far as I can tell is the fusible link in the power output from the alternator.
Is the alternator shot? Or the new voltage regulator?
I am aware of the the 3g alternator upgrade, which I fully intend to do soon. I have a bonus check coming from work at the end of January, and I plan to do that upgrade then. I need the truck until then, and if there's a wiring issue I can fix to keep it together for the next month and a half, that would be awesome.
Last note, the alternator tested good at O'Reilly's. Not sure if that's helpful or means anything.
Thanks
Thanks
