idi traveler
I would say that is correct, the path of least resistance should determine which one is dominate.
Yeah, so long as it is a parallel wiring. Parallel will double the current draw from the regulator - but the old mechanical ones are pretty robust. Wiring in series will lower the voltage of the signal to the second alt, which will only activate the first alternator in series and leave the second one off.
Now that I can see the schematic, I'm confident that sharing the F and S signal lines would work really well. I'm tempted to remove the regulator from my 3g and see if an external unit can drive it. Dual 3g's would seem like a lot of fun
wiring in series will lower the voltage to both alt., and neither will work. all you need to test the out put of an externally regulated alt is put 12V across F and S a good alt will produce a good output. If you are able to get a heavy enough reg. then parallel driving of the the 2 alts. might work. I don't think that there will be a dominant alt. though. The atl's will be unaware of each other, all they will see is the control voltage from the reg.
What I can foresee is if one alt has a diode, field or armature short you could back feed from one alt to the other and possibly make smoke somewhere other than the exhaust pipe.
another option would be to charge 2 batt's with one alt and 2 batt's with the other. Use deep cycle batt's for you stereo and you reg batt's for starting the truck. Seperate systems, no smoke, no get stranded.
