ericboutin
Yesterday I figured I had better try and figure out why my batt light is on again...last time it did this I had to replace both batts, the time before that it was the voltage regulator. Anyway I'm thinking regulator again cuz the batts are still new. The guy does the load test with his machine (Advance Auto) and it shows the alt is not putting anything out.
My question is this...how should he be checking it? He put the clamps on the hot and neg side of pass. side battery and then the little coil checker (tech term) around the neg cable?? He didn't seem to sure of what he was doing and I think the ole diesel kinda set him back as he wasn't sure what to do with the the other probe.
Continuing on...we put a new regulator on just in case and sure enough batt light is still on. I go in and say give me another alt. I pull off the old in the pking lot and he swaps my pulley for me and I put the new one on......ugh crank her up and the batt light is still on??? Anyway I go and get him and he says the new one must be bad and he doesn't have anymore will be today before he does sooo I take off with the "new" one in the truck and I'll swap out today.
Second question - on the drive home the batt light finally goes out and the gauge starts to finally move out of the red area like it's charging, the needle is not moving quite as far as it did before but appears to be charging. I was thinking I would have noticed immediatley with a new alt that it would be charging and the light would have gone out immediately? Would a new alt take a min or two to "turn out the batt light"?
Anyway sorry for the long post - but now I'm curious as to whether I should keep this alt or still go and exchange it for the new one he has on order?
Thanks
Thanks
I used the hand-throttle to bring the RPM's up to 2000 or so, and full-fielded the alternator (thought the alternator was going bad; turned out to be a bad connection at the VR)...and I don't have a tach, but I estimate that the engine bogged down at least 300 RPM's, and possibly more like 500.
...anyways this time all showed good - had like 13.7 volts from the regulator and 189 amps from the alternator, I think I have that right. Anyway last night the old one was showing no alternator found.
So anyway now she's got a nice new "rebuilt" 100 amp alt and a nice new shiny regulator too. Thanks again.
