Kelleyj1837
I noticed my battery light came one today. Took it to school put a vat machine on it when it was running it had 12.4Volts. I put the amp clamp on and got like 4 amps output. So knew the alternator was shot. went to the auto parts store and got a new one also a voltage regulator located on the passenger side finder. I put the vat machine back on at idle and got 13.6 running at idle, and like 60amps. So I figured every thing was good then on the way home the voltage meter in the cluster started to flicker from like 13-14Volts. Just back and forth if I turned on the heater on high it would stop and go to normal. So I guess my question is should that voltage meter in the dash move like that??
