Airdog Special Sale
MJ Synthetics
Site Sponsor
SoCalif.
Thats right gang the Original Airdog 100 and Airdog 150 Lift pumps for the Ford PSD, GM Duramax & Dodge Cummins are now available and on sale. Get the quietest lift pump on the market for your baby.
The AirDog® eliminates the air in the fuel that robs your engine of consistently greater performance and can also cause permanent damage to your injectors. The AirDog® also provides the fuel pressures and flows your diesel engine needs to produce maximum power, any time, every time! Get the full spray from your injectors. Get better fuel efficiency by taking the air and water out of your fuel before it gets to your injectors.
Doesn't matter whether you have a GM, Ford or Dodge Airdog has a unit for you. If you have been thinking of buying an Airdog now is the time to do it.
The retail on the Airdog 100 is 619.00 and for the 150 it is 629.00. You can find them at many Diesel Sites for 588.00 and 597.00. Now for a limited time both the Airdog 100 & Airdog 150 are $499.00 shipped to your door (lower 48 US) you can't pass this up!
