AcIdBuRn02ZTS
Pressure safety switch for pump driven centrifuge...
Hey guys..
Been tossing around an idea... trying to figure out a safe way I can keep my centrifuge running while I'm away from the shop for long periods of time (such as at work)
I started looking around for pressure switches that I could plumb inline on the pressure side... something that could kill the pump if pressure spiked over 100psi or dropped below 70 or so (clogged regulator or line failure)...
The first thing that came up was a pressure switch for an air compressor... 70psi on.. 100psi off.. adjustable and capable of handling the load of the motor.
Now... will the switch itself hold up to oil use since it was designed for air pressure? If no, is there anyway I could isolate the switch but still have it see pressure... but not have oil in contact with the switch itself?
Thoughts?
Thanks guys
-Chris
Hey guys..
Thoughts?
Thanks guys
-Chris
