add the small three lights
ISurvivedNMU
Michigan
I think they are standard on the F350 and duallys, but I would like to add the small red lights in the rear of the truck under the tailgate... Anyone got a good source, and wiring instructions....
gotdiesel?
Fine Diner
New Hampshire
ISNMU, I've got a buddy with 250 gasser who went down to the furd garage and bought the triple light, and then mounted it carefully in the center, thenjust tapped into the taillight wire in the 4-wire tow harness with one of those new-fangled watertight scotchlocks. I'll try to get the part # for the light if he can find it. It looks trick on a SWR and I'd like to add them to mine as well, tho they will obviously look better on the MOPAR!!!!!
Mastertech
Car Doc
Houston
Even Wal-Mart sells the light bar.
Then just tap into the tail lights back there and your all set.
jeepgod
Staff Sergeant
Iraq
yep.. i got mine at advance auto, was actually cheaper than walmart.... like 9 bucks.. the holes didnt quite line up.. i drilled two others and tapped into the lincense plate lights, works great...
jeepgod
Staff Sergeant
Iraq
ooops.. didnt even bother looking at the date on it.. i just got on this site.. and was looking through it..
thanks
Strictly Diesel
SUPPORTING VENDOR
Phoenix, AZ
If 3 is good...9 must be better... :D ;Sweet
All LEDs, plus 6 amber LEDs on each running board.
camoman
Has anyone seen the lighted mud flaps?? I seen a set on a dodge the other day and they looked pretty hot.. Any idea where to find them?
Bear Hunter
RLTW!
$10.00 at NAPA on sale and they are LEDs not bulbs like the ones from the factory
Mikes91
Melbourne, FL
Made in China quality vs OEM... What would you prefer on your $40,000 truck?
They're probably all made in the same place... :eek:
Nanohawk
