adapter Plate
912504x4
Troy IL
yes
I just put in a ZF5 and didnt have to change mine. I think if you try to use a ZF5 from the rear of a stroke you may see some differences.
Thanks,
Eric
Freight_Train
Traitor to the brotherhood
Gadsden,Al
Thanks,
Eric
Thanks,I have an engine that came outta a 5er and want to drop it in today.Didn't want to have to pick up my old engine to remove the plate since the cherry picker is in another bay.
Ceejmo
Smoke a Ricer today
Magnolia Texas
There is a 1 inch thick spacer between the flywheel and the crankshaft with the automatic. You will have to remove it for the standard.
Freight_Train
Gadsden,Al
Yea,I found out about the spacer hicky.I had to pull the Flex plat from my old factory turbo engine and install it on the Gear Rower engine(that didn't have a flywheel).Everything has been smooth so far.Static timed the pump thanks to Ziggy.THANK YOU for your gear timing write up since I did not want to pull the front cover.
912504x4
Troy IL
Did you still have one of the crankshaft spacers laying around? I think there is a guy over on F.T.E. looking for one everywhere.
I sold mine on the bay.
Thanks,
Eric
Freight_Train
Gadsden,Al
Thanks,
Eric
can't say I do.I wish I did though.Amazing considering how big of a pack rat I am......
