A question for Mel: GV 7 and 9 speeds
cleithau
Northern Michigan
I was wondering what are you getting these transmission out of? Do they bolt up to the transfer case or do you have to use a divorce mounted T-case?
FordGuy100
Silverton, OR
Now, basically what it is a the GV 7 speed is a T-19 4speed tranny with a gear vendors overdrive, giving you 7 foward gear choices. The GV 9 speed is a ZF-5 speed with a gear vendors overdrive that gives you 9 forward gears.
Double-S-Diesel
parts seller
derry pa
on a 4x4 the back half of the t case is modified.
on a 2wd the GV can be divorced.
