BigRigTech
Diesel junky
Ok, my truck is a 91 F250 2wd, 7.3/E4OD. I'm parting out a 96 F350 2wd, diesel as well. This morning I removed the rear brake drums, shoes, hardware and wheel cylinders from the 96, will they bolt right on to my 91?...Both have the 10.25 axle. The drums were almost new and my old ones are toast...MVI time is coming next month.
Will a vacuum pump of a 96 or 97 PSD fit an IDI if you swapped the pulleys? I have 2 PSD vacuum pumps here.
Next question, will the 2wd dual piston front calipers fit a 89 4wd Dana 60 brake system? And will the calipers from the 96 F350 2wd fit my 91 F250 2wd?...I grabbed those too along with some rear spring hangers, shackles, rear sway bar links and bushings and a few other minor items...On the plus side I was glad I grabbed the 2 tailgate straps off the 96, I broke one will unloading the 91 when I got home.
....Freebie fix, my favorite kind.
