A Heavy Titled 350?
OldIron82
Northampton PA
Hello all. I have a quick question. Does anyone know if a one ton F350 CAB AND CHASSIS ever came with a 14,000lb GVWR? My truck, a 89 F350 cab and chassis has the Sterling rear with 2 1/4" springs and a king pin Dana 60 up front. 8 lug. On the title, it's 14,000 lbs. I have it registered as such. Reason I'm asking, a buddy of mine was wondering how I got a "5" weight class sticker ( which is 14,000+lbs) when my truck is clearly a 8 lug f350. I have seen a Super Duty F450 of the same era and I gotta say that thing is almost as stout as my 2000 International 4700. Bigger rear, slightly thicker frame, and I believe 3" springs.
Now I looked at the sticker on the door... It appears to be 11,000lbs GVRW but it's pretty darn faded so it's possible it could say 14,000. Could there have been a mess up from the day the vehicle was purchased new and it got titled wrong? I'm not concerned about it at all if it is. Hell I'm happy. I would be willing to bet 75% of all one ton dump trucks are waaaaaaay over one ton anyway. I know mine is on a regular basis haha. So, thoughts?
Thanks, OI82
in 1989 commercial chassis F350 trucks were rated at 11k gvw. F-Superduty(F450) trucks held the !4.5k rating. here's what your door tag should look like.....
Shawn MacAnanny
Delaware
Yup both my 1990 and 1996 f350 cab and chasis trucks are 11k.. My non cab and chasis 1993 f350 was 10k. I just looked at a 1995 f450 and it was 15k.
OldIron82
Northampton PA
Thanks for the info. I guess somehow someone goofed on my title.
@Shawn MacAnanny: How do you like the R&D SX257 turbo? That's basically his stage one turbo compressor attached to the factory turbo hot side correct? Is it night and day from the factory compressor?
Shawn MacAnanny
Delaware
My truck was totalled in August so I only ran it for 5k miles. I had a wicked wheel in the favored 093 before, and I only ever ran either to 7psi since I had an engine being overhauled and studded I didn't want to blow up the one I had in the truck. It definitely whistles more. theres a YouTube video of the comparison between the two I took. The turbo itself was excellent quality
tke395
