international
Drownin' in diesel
this is for my 01 Yukon but should apply to an idi as well. Well, to make a long story short I replaced my compressor the other day. I flushed out the lines and condenser as well. I also replaced the orifice tube. I did not replace the accumulater or coil. The oil and coolant were filled to specs and low and high pressures were good. While driving to SC today the pop off valve on the compressor let loose and all my 134A is floating around WV somewhere. Is this caused by a clog somewhere? I should add too that the vent temp. never got below 60 at 20000 rpm. Not that it did before. Thanks in advance even though its a gm.
