A/C clutch engages the disengages
Suleiman Saadeh
North Carolina
I agree it would probably be a bandaid fix. I just want to have some ac since I'm in the truck several hours a day and it is getting pretty toasty.
If there is not shims or I cant fix it by modifying it somehow I'll probably just order a clutch and be done with it.
Clb
Another old truck
nannyfornia
@Suleiman Saadeh , to let freon out you just connect the top part with out the can to the lower a/c line like you did when you filled it and squeeze and it release into atmosphere .
When the a/c is on full blast does the needle spike ?
I think it's your compressor if you just are hitting it and it kicks back on , clutch related possibly, just trying to rule out my theory so you are not just throwing parts at it.,
Do not do this!
Dude really!
First ask The epa for your environmental ticket...
Suleiman Saadeh
North Carolina
The air gap was definitely the issue. I didnt think there was a washer in the plate because I couldn't get it to come out till I used needle nose pliers. I thought maybe someone had already tried to remove the washer before or something.
Ac is blowing cold as the winter snow.
I really appreciate everyone's help.
