Hey Justin what do you have with it? The turbo is the easy part, but at least Russ knows his stuff so you know whatever you got from him is good. I just had my ATS non gated system installed and the biggest problem I'm having is the upipe vibrating against the firewall. Make sure your cab mounts are in good condition and that you cut, peel or beat enough clearance for the uppipe and downpipe. If you need any parts, ATS is not the most helpful but some of their dealers are top notch. I bought some stuff from Central Motive Power in New Mexico and some stuff from JH Diesel in Mississippi. Both good folks to deal with with the CMP shop coming most highly recommended
The non gated turbo is a dinosaur but for your system its highly probable either of those shops will have parts right on the shelf. Congrats on the turbo. Are you going to install it yourself or have help or pay someone to do it?
