97 F350 front suspension radius arms
ipswichsprint
ipswich, ma
I'm upgrading my 1997 F350 7.3L Dually crew cab across the board. What I need to find are the front radius arms for the suspension. If anyone might know where I can source these parts (new, used, other), I would like to hear the suggestions. Finding these parts has been challenge so far. Thanks for the help.
JLDickmon
Bo Duke
49041. OU812?
not something you'd normally see fail..
why are you looking?
I'd think a junkyard that's a member of AMRA would be able to source it out if they don't have them..
ipswichsprint
ipswich, ma
Thanks for the response.
Upon replacing all of the suspension shackles through the truck, the front radius arms looked a little suspect. Was thinking that if I'm going this far with the rebuild, I may as well replace/rebuild all related components (bushings, shackles, shocks, arms, etc).
If I can't find any radius arms, I'm going to take them off, sandblast them, and get them beefed up at a local fabrication shop.
I'll check the noted yards per your suggestion. Thanks.
