BigRigTech
Diesel junky
This belongs to a friend of mine, cranks fine but no fire intermitantly. He was just about to call a wrecker after sitting in a parking lot for an hour this morning when it started out of the blue. He brought it to my house, shut it off and it wouldn't start again. His E4OD trans is acting funny too, shifting very firm all of a sudden (this started this morning). No DTC's flashing on the O/D light. No DTC's in the PCM according to my scanner. After it sat for about an hour it started in nuetral but not park...Started several times this way. We replaced the trans range selector thinking we had it and it worked A1 but the check engine light was on when the truck was running. He took it for a test drive, came back, shut it off - no start again.
We replaced the cam sensor for the hell of it even though the tach was reading cranking speed - no change. Seems to be temperature related and electrical related . I think it's the trans shutting the engine down possibly as he said it's acting completely different than it usually does. I repaired a corroded wire on the bottom of the fuse box for relay #1 (PCM) as it was very green and swollen. I tried unplugging the injector harnesses one at a time while cranking - still nothing. I'm letting it cool down for a few hours and I bet you any money it will start.....Sitting right in the middle of my driveway....
...Any idea's???
....It fired right up once it was timed but I couldn't run it long with no serp belt or coolant in it...
