thel33tone
forgive me for being a newbe but truck isnt running and i cant find a topic anywhere to help, i took the hpop reservoir off and when i crank the truck over no oil comes up. its in the good part on the dipstick. for the longest time i had an injector pressure too low code (1283 i think) about 2500 miles later it just wouldnt start. i think its either the high pressure or low pressure oil pump. before i took the hpop reservoir off i filled it with new oil and cranked it, nothing. also the whole while monitoring the pressure regulator (which i just installed to try to fix the truck and it didnt so thats brand new) duty cycle is at 55% and the injector pressure and absolute injector pressure are both 0% flat lined all the time. no disconnected wires and the buzz test works great. i had full power till the day it died. i also change the fuel filter. i cranked the truck with the fuel filter cap off and it filled up so i know its got fuel. i also bled the air out after changing the filter via the shrader valve. thanks to whoever can help. also i tried it without the wire to the icp sensor on the reservoir, no change
