94 7.3 idi white smoke on decel
torinoracer29
wonder lake, IL
I just had all 8 injectors cleaned checked and reset to proper pressure. It smoked on decel before they were done and now I think it may be smoking a little more than before. It has 160000 on it and I am stumped any help would be great.
Shadetreemechanic
Monteagle, TN
Injection pumps bad. Been there. The problem is with the timing advance on the drivers side of the pump. You can verify by moving the advance arm with the truck idling. If its working the truck should start smoking like crazy when you push it, but yours won't.
FordGuy100
Silverton, OR
Just keep running it. If it starts and runs ok you are still ok to drive it. White smoke would mean retarted timing?
Shadetreemechanic
Monteagle, TN
You could try advancing the pump, but I don't know if it will help. There are lots of threads on here about advancing pump timing.
