93 turbo idi questions
1992F-250IDI
pungo va / va beach va
alright so im doing away with the factory airbox but i dont know what do do with the breather tube that comes into it my pushes a little oil so i would rather not run it in my intake can i plug it or re rote it somewhere thanks guys
No you can'y plug that line. Thats the vacuum pull from the crankcase and our engines needs to have the blowby vapors sucked out of the case. If they are not drawn out you will create oil leaks from the slight pressure buildup. Some can get away with running that hose to the ground but it still can blow oil from mains and pan plus most other gasketed areas.
