91 dt360 - 88 for 250 can it be done?
dta360
Ten sleep, Wy
Hello i have might have acses to a 91 dt360 out of a bus my main concern is that i might not be able to get the engine mated to the zf five speed transmision in it would anyone have any insight to this question?
nevrenufhp
torque ******
Sacramento
Yes. If you do a websearch for pipewhiner on many diesel forums, he has a few made. It's the trans adapter, and flywheel to mate to a ZF. Another idea, you could get a pretty nice 10 speed for that price.
dta360
Ten sleep, Wy
humm Ten speed that my be an option but i already have the tranny in the truck i might look into that though. on my initial post i forgot to say that i was trying to put it in a 88 f250
Exekiel69
2wd or 4wd? If 2wd then it will just too easy to make a crossmember and modifications to accommodate another transmission already matted to the dt360. If 4wd then there is more work involved.
Personally I would pick a md transmission over a ld transmission for longevity reasons.
dta360
Ten sleep, Wy
yes i have wondered about that. im wondering if getting a adapter plate machined or shortening my drive line and moving my transfer case and lengthening my for wheel drive, drive line or go 2wd its 4wd if you haven't guessed already. oh my grammar fail but i am not sure witch would cost more. the dt is mated up to an allision 545 auto so i would like to know how well they perform not to knowledgeable about transmissions.
dta360
Ten sleep, Wy
humm darn is there anyway to upgrade like the tourque converter and larger pan and maybe a remote cooler or is it still just crap?
nevrenufhp
torque ******
Sacramento
Even with a low stall converter, it's still going to feel like the engine is connected to a rubber band. Add to that, a 230hp rating, and you get a grenade.
rjjp
Needs to go test
Clare, Mi
Once you find a suitable MD trans, just go with a divorced transfercase.
dta360
Ten sleep, Wy
ok any suggested tans that would work well?
could it be put up to the zf5 transmission? or is there any other transmission that would bolt right up?
nevrenufhp
torque ******
Sacramento
The SAE transmissions they came with are pretty strong. Comb thru a truck wrecking yard, and see what they can help you come up with.
swamp_ratt
Oh yeah....
Hudson, wi
I'm running a 6spd allison 1000 from a duramax behind my dt360. Buy a allison 2000 bellhousing and bolt it to your 1000 and away ya go. Can use the 5spd Allison too
Lance
