7.3L return line T's?
6.9poweredscout
Bleeds IH red...
Northeastern Pa
yeah, getting carried away with the posting here! LOL any idea where i can get a set of the JUST the plastic T's for a 7.3L. i want to use them on the 6.9 but i dont need a KIT. the 6.9 kit i got i didn't like because the fitting were reallllly small and the one appeared to be broken.
-Jon
Diesel JD
Gainesville, FL
You can get those Ts at IH or Ford, I don't know if it would be more cost effective just to buy another kit if you really want the 7.3 leakoff Ts. The easiest thing would just be to buy one to replace your broken T. The 6.9 returns might be small but they are plenty big to do the job of returning fuel to the tank. You can use either you just can't mix and match.
tbutt130
Cabot, AR
Just curious, where do you find these kits. My searching online has not found a "kit" yet.
Thanks.
91crew
San Luis Obispo, CA
Why can't you mix and match? I pieced together a couple kits no problem. You just have to try harder to get the smaller hose on there or tighten down a larger hose more. You can find the kits on ebay for $29 shipped. "return line kit ford idi" etc.
