7.3L IDI Industrial Motor Mounts
ColLonewolf
Eustis, Fl
Anyone have a set available? Would be good to know what trans was mounted to it as well but not mandatory. Thanks.
Booyah45828
Ohio
No idea what the industrial units had. Navistar units had 2 pucks beneath a bracket below the balancer, then they had a v shaped mount off each side of the flywheel housing. Most of them had nothing on the trans, but if you ordered an mt6xx allison, it would have a rear transmission mount on another crossmember at the back of the transmission.
ColLonewolf
Eustis, Fl
Trying to put a 7.3L IDI in a 72 F600 with the 330 gas in it. Uses Industrial mounts as there are no spots for traditional motor mounts. Was thinking International IDI mounts. Looking for options.
Booyah45828
Ohio
Well, look at the flywheel housing on the back of the engine.
They can use something like this.
Or like this.
Booyah45828
Ohio
Both mounts are on the flywheel housing though. And you can see the front mount bracket in both pictures too.
Booyah45828
Ohio
All of your medium duty options, so allisons, spicers, fullers, etc.
It's an sae2 housing, so anything that's sae2 sized will bolt to it, so long as your input shaft depth is correct. Some use an sae3 housing, and there is an adapter ring installed then to go down from 2 to 3.
