Tyee II
I am about to change out a 7.3in a 1992 F 350 with manual ZF5 transmission. I have read several threads on this site and have a few questions regarding this process.
Engine lifting ? Is lifting from the 2 original eyes that are bolted onto the intake pan bolts adequate ?
Unbolting clutch and leaving on input shaft ? I have read several times on this site that this is a workable situation. Can the transmission be left in place ? The clearance problem looks to be front of oil pan into crossmember as engine comes forward, will this clear leaving the clutch on the shaft ?
I have overhead trolley and chainfall with lots of headroom, so I will have very good control of the engine. My preference is to do minimal moving of the transmission /transfer case. With drive lines removed it appears the slots in the transmission mount will allow about 3/4 inch movement forward and backwards ?
Radiator is out and the components on the front of the engine are removed so I have decent working space in the engine compartment.
Any other advice is appreciated. Thanks in advance.
