Ok I have a 94 idi turbo 7.3 that has a miss in cylinder 6. Started doing a compression test and found oil on #6 cylinder. This truck has 100,400 miles on it. Took the engine apart to find no broke rings and no play in the valve guides. The intake valve on cylinder 6 has a build up of carbon on it but not enough to keep it from seating properly. Compared to the other intake valves only having soot on them. Valve stem seal was good also. This engine when running is smoking blue at idle cold and operating temp. Compression on cylinders was 425. Wasnt able to check #6 because of the oil in the cylinder. Help me out why do I have a miss.
