7.3 idi run rough/miss then die
93f250idi
strokin
cadiz ky
:mad: today i went an got a straight pipe put on my truck an as soon as i went to back into its parking spot it started missing and not wanting to rev then died. cranked on it 2 or 3 different time an it finally started an ran good. drove it around a little while an it will run perfect then all of a sudden start missing an die again. i have no clue what it is an need some help quick! an my gp light stoped comin on this afternoon too if that helps . i really need to fix this truck quick so any suggestions will be very appreciated. thanks!
lotzagoodstuff
Carmel, IN
Fuel system/air intrusion or possible your fuel tank siphon.
How much fuel in the tank(s), and when was the last time you changed the fuel filters?
93f250idi
strokin
cadiz ky
ok ill pick one up tommarow when i pick up my gp's. got a new gp realy today it listed for $243 i got it for $139 with our discount!!
93f250idi
strokin
cadiz ky
ok so i took the bottom of the fuel filter off today an the nastiest looking fuel ive ever seen came out!! it had all kinds of water in it. i cant get the filter itself to break loose. any tricks? thanks
A BFPP.
A big... pair of pliers.
FYI, there is a drain in the bottom lid, you usually open that first before unscrewing. Not for technical reasons, other than it helps limit the mess.
93f250idi
strokin
cadiz ky
ok well its a little to late for the drain haha but i got it off now what do i do to the new filter before reinstalling? do i fill it up with fluid or will it fill itself up? thanks
gatorman21218
Ashland VA
If you havent already done so (sorry ive been out of town) fill the new filter with 50/50 ATF and Diesel Kleen or the like. Helps to clean out the fuel system. If you leave it dry youll be cranking forever to fill it up and prime the system.
BTW a oil filter wrench that fits the oil filter will also fit the fuel filter.
93f250idi
strokin
cadiz ky
ok got the thing primed back up let it idle for about 5 mins done perfect now its doing the same thing it was it will start runing rough an then die. i cant figure out what it cold be other than a fuel issue. guess its time to get the brakes unstuck on the f150 an mess with it a little while an take the f250 to the shop
hesutton
The Anti-Anderson
Bowling Green, KY
What does the fuel look like in the bowl now? Any better or still nasty? If nasty, you have to drop and clean the tanks.
Heath
gatorman21218
Ashland VA
X2 heath. You very well could have algae in the fuel. If you do have it (usually seen by black goo in the fuel filter) you need to drop the tanks and clean them then run a "shock" level of Biobor JF to kill any remaining algae. Also keep changing the fuel filters until they are clean. http://www.filterbarn.com/ has the best prices on filters (i run International fuel filters from there)
93f250idi
strokin
cadiz ky
the fuel is alot better no more water in it i got the drain to break loose so i can drain it now. it seems like it can idle forever perfect untill i drive it then it wants to cut up an die.
93f250idi
strokin
cadiz ky
thanks for the site! napa wanted 40 something dollars for one i got one for 18 shipped! less than half price!
gatorman21218
Ashland VA
yeah napa is a joke. I ordered 12 IH filters for 9 bucks a piece and got free shipping. To say the least I have a few spare filters.
Also if you didnt already know, put some oil on the o-rings when you spin her on.
Back to your problem... I'm going to guess its the IP but I could be wrong. I have a feeling though that water clogged it up. Did you try running the ATF/Diesel Kleen through the filter? Maybe that will help clear it up
