7.3 IDI build
Oil_Huffer
ct
Hi all,
need advice on how to rebuild an engine from ground up. this is my first engine rebuild, but ive pulled engines, done head gaskets, etc.
a little backstory for those interested. my 7.3 blew head gaskets on highway, was able to get the thing running to a gas station to call a tow to my buddy's house. pulled the engine and relaced the gaskets, go to turn it on and hear a thunk. look in the bay, and there's coolant up to my manifold. pretty sure i got a hole in the block, since it filled that much in the ten minutes between filling my radiator and me turning the key.
found a 7.3 idit that a guy had recently had remachined and bored out on marketplace that i can put in, only problem is its in complete pieces.
u2slow
bilge rat
Coastal BC
The Tidi is the one i would build.
Do some homework though. If its not complete, make sure you have sources for what you're missing. The crank, rod, pistons are specific to that factory turbo edition.
Mike_Dawson
