7.3 cooling mod
DrCharles
West Plains, MO
Yeah, that's why I asked. 2-cylinder John Deeres are another one of my hobbies, and I have read in several places that the 435 (with its Detroit 2-53) really needs higher compression pistons, and injector upgrades, because they are very hard to start in freezing temps or below.
Joseph Davis
Lompoc, CA
Thanks for the cool information. I order my 6.9 head Gaskets and will pull the plugs and post the info when done. The holes could have been for casting the heads at factory it gives the machine reference point to start milling the heads and block down the line. Thanks for the reference to your post. :cheers:
You're welcome. I did it to try to help others understand what's involved. I also tried to break down the explanation to a very basic level since a lot of readers may not have ever been inside an engine before. These same holes are open coolant passages on the 6.9 blocks.
Justin B
Virginia
So I remembered reading something about this "mod" during my research. I've got the heads pulled off of a 6.9 and the heads have plugs in them. I'll attach a picture for reference. I figured out earlier that this motor was rebuilt, now I'm also assuming it had a head job and they put those plugs in assuming it was the same setup as a 7.3?? A lot of what ifs with this motor at the moment, and I don't have any history on the shop that did the work. I'm half tempted to leave them alone, half tempted to yank them out.
Administrator Moderator
If it is a 7.3 head on a 6.9 block, show us a couple pictures of what they did for the bolts/studs.....
7.3 = 1/2 head bolt
6.9 = 7/16 head bolt
There are some solutions out there, just wondered what they did on this one.
Justin B
Virginia
So it's definitely a 6.9 head, just tried some 1/2" bolts and they don't fit, measured the hole and it comes in around .475, ARP stud threads measure .437 (7/16).
Head has slightly off center glow plug holes as well.
That’s insane. You have a real one of a kind head there, I’ve never seen or heard of any 6.9 heads with the 7.3 treatments. What year is this engine?
BR3
Mt.juliet , TN
I've got a "certified" 87'. 6.9 in the basement about to be torn down for a rebuild, so when I get the heads off, this will be the first thing that I will check. I've got the 7.3 style glow plugs system for sure on this block, but the flywheel seems to be a dual mass, and I read somewhere that 87 was supposed to be the only factory year for single mass.
I'll get it torn into and report back what I find
Sent from my Moto Z (2) using Tapatalk
Macrobb
North Idaho
So, just thought I'd chime in again. A few weeks ago at Hunting 4 Horsepower, I saw Justin of R&D IDI Performance and actually asked him about this cooling mod(considering he's going all sorts of mods to make power etc). He doesn't see it as doing much of anything and doesn't see any issues with cooling in stock 7.3s - the limitation is simply the radiator.
Now, I'm not entirely sure he's 100% correct, but if there's one person I'd take the word of on something IDI related, It'd be him.
With a stock 7.3, I'd tend to agree. I think it would make a bigger difference when you turbo one and turn up the fuel to get more power out of it. I think it would be more of a benefit with a Factory Turbo engine Vs. one that's N/A since it already has a power adder.
Macrobb
North Idaho
Sorry, by "stock 7.3" I meant one with this cooling mod. He's got 300-400HP IDIs he's working on(including the ~400HP bronco that he ran there) and didn't do the mod on them.
tke395
