7.3 bell housing to 435 trans
dirtdiggler
brown city michigan
Looking for interchange bell housing fo my future 7.3 diesel to mate with my 4 speed 435 in my 67 ford f250.currently i have a 360 FE engine
Dieselcrawler
Professional wrench holder
Quakertown Pa
yep. all ford 4 speed truck trans use same 4 bolt pattern and spline. i have a 435 where my t19 used to be. but there is no 4 speed bell for beind a powerstroke.
rjjp
Needs to go test
Clare, Mi
I thought the 1st gen 7.3 stroke had the same bell housing as the IDI, finding a clutch could prove difficult though.
subway
be nice to the admin :D
York PA
Why not? The 5 speed can interchange, or is it all in the clutch?
For what you need a regular diesel 4 speed bell housing will work like mentioned.
82F100SWB
Sioux Lookout, Ontario,CA
A SMF conversion setup with a 4 speed disc could work, the input shaft on the ZF is bigger than the 4 speed one. I would do a ZF swap in the truck though, no o/d with a diesel in a truck with poor sound deadening is very ******* the head.
truckonfire
