first of all, the mounting bracket is cheap and plastic.
second, 1/4" NPT for fittings??
but it does seperate water.
supposedly it puts out 9-11 psi...
we shall see.
MADE IN THE U.S.A.
i see alot of you guys running this on your firewall,
i suspect this pump is designed to pull fuel?
im almost tempted to leave the holley black pump in.....
thoughts?
we shall see.
MADE IN THE U.S.A.
thoughts?
The pumps are called dura lift for a reason self primes to to 10 feet so you can mount it on your cb whip if you want these also have a seriously long service life. The are used as OEM equipment on the diesel powered ****** units on semi trailers that sit in the wet, dirty salty road spray for years.
