In theory yes, but in reality no. The luminosity method relies on the injector to operate in spec. If #1 is weaker than the others, your timing will be more advanced, where as if it is stiffer, then your timing may end up being retarded. Because the pulse method is triggered by the rise in presure from 0psi to anything higher, the timing is actually set by what the pump sends, and not what the cylinder recieves. Having used both methods, I vastly prefer the pulse method for it's reliability and accuracy.
