oleblue85
I will be installing the zf 5 speed to replace the t19 this weekend and want to have everything when I do the swap. I was given a luk smf and ordered the smf clutch kit 07-131 for this flywheel. I do not have bolts for the new set-up. My questions are:
The flywheel looks to be in good shape... should I have it resurfaced?
Do I need new flywheel to crank bolts for the luk zf5 smf? Or can I reuse the bolts off the t19 flywheel?
What would be the length and thread count for the luk smf to pressure plate? Do the t19 smf bolts work for this?
Thanks for your help.
