The PSD is an all-electronics engine, there ain't even a throttle pedal cable. The PCM will be looking for all sorts of sensors that will not be there with the IDI, so you should swap in a PCM from an IDI truck, those only manage the trans.Will probably have to swap main harnesses as well...
