Buying a running 6.9, just the motor. Plans are to rebuild it, but that's down the road. I have an '88 7.3, and I'm wondering what parts swap between motors? Injectors, lines, manifolds, etc. Anyone know?
What will swap over. IpInjectorsWater pumpIntakeExhaust manifoldsSerp set upAlternatorIp LinesValve CoversCrankCamRodsOil squirtersPiston?Oil pumpOil PanOil CoolerAll the bracketsI don't think the 7.3 heads will go on a 6.9 could be wrong Tho
I believe the heads have different sized bolts and a different cooling passage. I THINK the heads can be swapped using special studs but I'm not sure. I believe the valves, rockers, can be switched however.
Almost everything. Lol
Obviously pistons are a different size.
Early press in squirters obviously won't work in place of bolt in one's and vise versus.
we all preach it,
no one ever uses it.
i like how nobody wants to work, they just want the answers handed to them.
IMO i think there should be conditions before youre able to post.
nothing too crazy, just a mandatory read through the stickys and tech articles.
perhaps a 10,000 question pop quiz.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
