50%WMO/ 50%K1
bagpiperjosh
Windber,PA
I put 50/50 mix with k1 in my truck and it started just fine in 25ish degree weather.(it smokes a teeny bit at cold idle) So im thinking this is a good winter mix for me.. Anyone else do something close to this?
subway
be nice to the admin :D
York PA
i have run 50/50 in the winter but with diesel, its a little easier since i can pull up to the pump to top off. i cant do that with K1 around here, you can only fill it in cans and transport it that way.
bagpiperjosh
Windber,PA
yea, same here.i just happen to have a blue kero can because i have a kero heater
Blind Driver2
New Albany, In
You can probably go with diesel instead of K1. Diesel here is $4.20, K1 is $4.55, but there is a noticeable difference in viscosity between the two.
Bo17
