35 gal front fuel tank install
rustyescott
waco tx
Hi all. follow along as i try to install a 35 gal front fuel tank , in my 1993 f350 dually pick-up. (tank info) replacement tank is from a 1992 e350 7.3 diesel van. tank is a 35 gal. measurement are as follows 71x18x11 pt#is f41a. f350 tank measurements are 58 7/8x 12 1/4 x 12 1/2 pt#F6C, THIS INFO IS tankstopans.com .enclosed are pics of the 2 tanks.
sorry if pics not inline.
Greg5OH
MI
this is something id be very interested in. so i could try stuffing a spare tire under there.
WATCHING THIS FOR SURE...now is yer truck 2x or 4x?
You have not filled your signature out so we could be missing details!
Al
rustyescott
waco tx
35 fuel tank install
more pics.
rustyescott
waco tx
35 gal fuel tank install
ok just finished somemore measurements . looks like i have 13+ inches of ground clearence, may have some interferce around swaybar area. fuel tank frame mounts are drilled for more than one tank size and that was my major worry. will be useing van sending unit due to it being biger than truck. same ohms reading. may have to extend fuel fill hose. and move fsv futher forward for eaze of access.
LOoking good so far,
So does the tank go a lot further forward from stock? If so about how much?
How about towards rear diff? How far from center of rear axle or say the shock mount on axle?
I'm concerned about the length not fitting under my truck as I'm a regular cab 4x so cross members come into play that you do not have. AS you are a CC that changes location compared to a RC
Thanks
Al
BTW great info!
rustyescott
waco tx
wery good question AL. van tank has wider recess's for straps. i should be able to slide tank forword to clear swaybar, and just extend fuel fill hose . cause i'm dictated by swaybar location, got lot of room forward of fueltank.trying to keep fill hose in same area as it is now, but if i have to slide tank forword i will.i'm all so doing fuelneck mods at same time.
eastsideauto
Denton, NC
Very interested in this mod. Fuel filler necks aren't a prob for me as I have no bed now and fixing to build a flatbed.
rustyescott
waco tx
eastside auto you will have it easier than i , i just found out i have a bed crossmember in the way , about all i'll be able to slide forword is about inch1/2 . but we will see
gandalf
Senior Member
CA &/or Maine
I'll also be following this closely. Our trucks are similar, other than the transmission. If everything fit on your truck, it should on mine too.
You're taking plenty of pictures. That's good. Take lots more. Do a full writeup, all the good things and all the bad/hard things. That will help all the rest of us.
Greg5OH
MI
off toic but my truck doesnt have a sway bar...front or rear, what the heck!
