24v flamed out......
geonc
SPIDER BAIT
NECKVILLE North Carolina
company '99 24 v was idling then drop in gear...flame out:eek:
Started up then died again cookoo
Have fuel all way to inj pump banjo fitting.
Is this a similiar to PSD CPS type failure :confused:
'lil help guys :cheers:
Batman
any codes?
how's the fuel pressure?
sounds like it could be the injection pump.
Whit
lost in Why-homing
Geo......I assume this is an auto tranny.....if so reset the tps.
turn key on but dont start
slowly push throttle to floor and slowly back to idle position.
turn key off
rtestart and see ifin it works better
holtzer1
missouri
had one do this...turned out to be a locked up torque convertor....does it lunge really hard before it dies? if so, this may be your problem..if not...not the t/c this time
geonc
SPIDER BAIT
:cheers: guys!
Thanks for the info......Kevin, cookoo on the TPS thingy reset :D
T/C locked up :confused: cookoo I've had std trannys for the past 600 odd thousand miles LOL but I'll look into it...if the damn thing will start -cuss
J.Keith
Loveland CO.
Crazy thought but it may be the security system. Make sure that you unlocked it with the remote (if it has one) If the headlights are flashing this may be the problem.
I know I was stumped on that for a couple hours once and thats exactly what the truck would do. I started it and it was ideling just fine. As soon as I pulled it into gear it died. After that it wouldn't start again.
Good Luck
Seven4eight
