2002 7.3 f350
texaspipeliner
Pete Hollyfield
silsbee,texas
Hey guys my 02 died yesterday and won't start my programmer won't connect I tried to use it to get codes but no luck the only thing out of the ordinary I can see as of now is that when I turn the key on the wait to start light never goes off or the check engine light even when cranking anyone have any ideas
texaspipeliner
Pete Hollyfield
silsbee,texas
Yea I was just gonna check since I had it handy and I was gonna de tune the truck but it won't link up to it so I can't remove it or anything I'm baffled
texaspipeliner
Pete Hollyfield
silsbee,texas
Also I just found out number 22 fuse is blown and apparently the circuit is shorted out somewhere because a new fuse blows as soon as the key is turned on
trackspeeder
Stone crusher.
North Branford. CT
Unplug the fuel heater and replace that fuse. It should start up.
Fuel heater most likely has shorted out.
With fuse 22 blown, no programmer or scanner will connect to the PCM.
texaspipeliner
Pete Hollyfield
silsbee,texas
I have an edge evolution but I'm pretty sure its useless now lol but I'm not putting it back on my truck when I get it running again it can stay stock until I buy a ts6
I would say pcm before idm.
Pcm controls the glowplugs and the check engine light.
The edge may not be able to pull the real codes.
Also check the relays. I believe there's one for the PCM.
madpogue
Madison, WI USA
Refer to the owner's manual, and disconnect EVERYTHING associated with fuse #22. Then install a new fuse, and turn the key to RUN. If it doesn't blow, turn the key off and start reconnecting things, one at a time, and turn the key on at each step, until it blows. That will tell you what has shorted out. IIRC, your truck has both a glow plug relay and a similar high-capacity relay for the intake air heater. On the earlier models, the GP relay was also energized by this same circuit. Same may apply, along with the IAH relay, to your truck. So I'd start by disconnecting those relays.
Waystro
No Class
South Texas
Hey your about 20 miles from me I'm just outside of Fred
Good to se a fellow Texas member. ;Sweet
crispy74
