mblaney
I am having problems finding the correct part number for the 30 spline outer axle stubs for my D60 (left and right are the same). For some reason my donor D60 came with stubs that don't have a clip ring at the spline, plus the shaft diameter at the needle bearing is 1.46" (needs to be 1.5")
I am finding lots of misinformation regarding the correct part number depending on the year of the axle (1993). Does anyone know the correct part for this? I need the snap ring groove at the outside end of the spline.
Yukon part D48903 looks good http://www.yukongear.com/ProductDetails.aspx?ProdID=3610
but the same number in Spicer is not right http://www.dennysdriveshaft.com/p16...ter_axle_1988_to_1998_f_350_with_dana_60.html
I looked up Yukon D620085 and that appears look right but that is specifically for 1979 - 1988???? The picture might just be borrowed from the 48903
http://www.yukongear.com/ProductDetails.aspx?ProdID=3609
