hey all,
is the 1990 cummins 6 out of a dodge a non electronic model like the 94-98?
If it has electronics what?
Wrong place to ask but, yes, the 1990 Cummins, commonly called the 1st Generation Cummins, is purely mechanical, requiring absolutely no electrical influence to run. (or start, for that matter, providing it can be roll-started)
Actually, the 1989-90 are better than the later versions, having a larger injector bore and larger injectors than later versions, along with a few other advantages, such as a DUAL-CHAMBER diaphragm vacuum-pump.
1st Gen. are 1989-1993, with inter-cooling beginning in 1991.5
2nd Gen., P=pumped, 1994-early 1998
Both above versions are purely mechanical.
The 1998.5 until present are various versions of computer-controlled electronic engines, plagued with a host of non-mechanical headaches, such as in-tank lift-pumps and electric injector-pumps, along with computer monitoring of engine functions.
