18.7 MPG
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Finally got a full test on my rig. 18.7 mpg on the highway in frigid temps. Engine never really gets hot enough, I need to replace the T-stat.
This is on a 2wd truck with an honest 300K miles, 5speed with 3.55 gears,and on that tank at least 40 minutes of idling time.
I used my GPS to track the miles travelled, so this should be accurate.
I cannot help but to think though, that at 70 mph, my rpm is still too high. About 2400rpm.
I dont really pull heavy loads. I am thinking a taller tire will drop my RPM some.
Any thoughts?
Dave7.3
Diesel ******
South Dakota
Almost 19mpg isn't bad at all! I'm sure a working thermostat would put you in the low 20s at least. ;Sweet
Are you sure you have 3.55s? My truck has 4.10LS and turns the same RPM as you at 70... cookoo
Silver Burner
Burnin' Oil&Rubber
Beaverton, OR
I have 285/75's with 3.55 gears and an E4OD and in OD at 70 I'm barely at 2000. I think our OD's are similar ratios too. Even with 235-85's you shouldn't be that high though it seems...
93_444idi
first on race day
missouri
with 4.10s and 33s I turn ~2400 at 70 as well.
bigger tires will lower your rpms, but your engine will work harder to turn those heavier tires.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Hmm...got me thinking.... (yeah yeah insert smoke joke here)
When its really cold, the tach acts funny. I bet its not accurate.
According to the code on the door tag, its got 3.55 gears. I am going to change the fluid soon, I will verify.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
If it wasnt for the blue smoke, I dont know if I would even touch the injectors/pump. But I know I am leaving something on the table with these worn parts.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Absolutely true. I sold tires for years, and the biggest complaint with taller tires was a loss of accelleration.
I'd like some aluminum wheels to lower the unsprung/rotating weight.
Dave7.3
Diesel ******
South Dakota
Have you been using any fuel additives? My truck used to smoke blue like a banshee under any kind of throttle. A few tanks with some diesel kleen and my smoke went away. Others on this board have had success with Howe's diesel treatment as well as a few other brands that I'm not familiar with. ;Sweet
Matrix37495
The Amish Wolfman
Terre Haute, IN
If it makes you feel better, i got the same mileage on the first tank of my 2000 Ranger....4cyl/5 speed/2wd:(
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Blue smoke went away?
I got to say this truck stinks though.
Dave7.3
Diesel ******
South Dakota
Yep, smells terrible! Simple fact is the ULSD is hell on our injection systems. Using additives will bring your system back up to *****, that is if it isn't too worn out to start with. Better to start with the cheapest alternative first! ;Sweet
NTOLERANCE
I'm the cotton swab
cottage grove, wi
I forgot, I had 700 lbs of steel in the back too.
I am going to try the additives and then look into pump timing and pressure.
Bo17
