I thought that mixing tire types was a big no-no?
Why would the steers care whats on the rear? Now you got me interested.
I myself like the BFG Rugged Trail. They are what came stock on the Superdutys in the 99 and 2000s. not an overly aggressive tire but do quite well in mild off roading. And they wear well will almost NO road noise or cupping.
If they would come in a 315 i think that is all I would put on my trucks.
Now, If you never leave the pavement, then the bFG Commercial Traction is for you. Last FOREVER and are a quality built tire.
No I am NOT a real BFG fan. I wouldnt run the all terrains if they were FREE and I used to like the OLD mud terrain but absolutely hate the new design. I just like the 2 tires above
think thats only on the same axle.
What sorts of problems, exactly?Radials on the rear bias on the front should be fine. It could cause problems if you have bias in the back and radials in the front.
Handling problems. Radial tires grip the road better than bias ply's. So if you were to have radials up front and bias ply in the back it could be a dangerous handling situation.
you guys aren't supposed to make me work
let's keep it clean eh?
now about the made in China tires......
the chinese will build whatever you spec. Most american tire companies are sourcing chinese made tires too. So is Nexen. Don't assume the name means anything anymore. this week my tire warehouse is having a special on Hercules Alltrac A/T. Hercules/Cooper....supposedly an american name.....this 235/85/16 is made in China. yup. 17/32 deep lugs, not bad looking, ok sidewall stiffness, balances out ok. my cost $109ea. it is what it is guys. now would I buy and install the chinese domestic branded stuff...not a chance in hell. those have no min spec let alone quality control.
BURT,
I am very sorry for your bad tire luck.
Please don't take me wrong as ---
I am gonna exonerate the un-sub/suspect in this case.
I have had too much experience with purposefully knifed and ice-picked tires.
Most cases are the result of a jealous husband or boyfriend.
Also, over the years, we have had situations where every tire in a church parking-lot has been stabbed and every last one of them flat as a board before church let out.
Anyone knifing a tire wants to see it flat and a knifed sidewall will go flat within seconds.
Also, unless they get caught in the act, they will knife every tire on the vehicle.
Radial tires have paper-thin squishy sidewalls that are almost touching the ground when the adjacent tread is on the ground.
The weakest point in a radial sidewall is that point just where the tread stops and the sidewall begins.
My theory on your situation is that you ran over something sharp and it was purely a case of luck of the draw.
Then, again, I could be wrong.
Not to argue, but not to put a bunch of mis-information out there either, the radial/bias mixing on different axles warnings are mostly un-proven myth.
It may hold true on some wimpy 1500-pound front-wheel-drive rolling-casket; but, on a heavy 3/4- or 1-ton truck, one will never know the difference with radials on one end and bias on the other.
Over the years, I have put many miles on mixed tires with sometimes the radials being on the front axle and sometimes on the rear.
I have never had a single issue, regardless of how slick the road, how heavy or light the load, or how heavily the braking application.
I am speaking from actual seat-of-the-pants experience and not from some drawn on paper or test-track theory.
i have a buddy who swears by them too. he's a little more scarry though. he's got bias on the drivers and radial on the steer
